Sorry for resurrecting old thread, but I am desperate.
my setup: FR motor and prop (6 inch), Raiden 7, 14s12p 30Q, erayfoil remote and metr module.
No matter what I change in vesc tool, I can not solve my problem, which is: when bench testing my motor in 200L barrel of water, I am always drawing max motor current but without max rpm. started with 120A motor amps, now testing with 180A motor amps and still raiden is sending maximum 180A to motor with full throttle but not getting maximum rpm. (throttle on remote 100%, duty cycle in log 39-60% depending on max motor amps). Without active cooling, raiden is at 80 degrees in few secs. and I am talking about testing in barrel, so no wings, no my weight on board, just motor and water.
What I tried so far: few motor detections, both through automatic and manual detection, manually calculating flux linkage (almost the same number I get during motor detection), turning off phase filters, changing motor current (from 60A to 180A), changing from Current no reverse to Duty no reverse and doing input setup few times, changing remote from erayfoil to gt2b remote, changing throttle curve to expo… tested after each change and there is nothing I can do to fix behaviour of my setup.
@Manufoil seems like you had same problem but managed to solve it with increasing max motor amps to pretty high numbers, which doesn’t look like actual solution to me, more like bypass of a problem. or did you find in meantime real cause why you need such high currents?
latest metr log with 180A motor current:
