After quite a few revisions but enough rides to justify it in season 1, I will make a new lightweight setup to use with my takon slate V2 surf foil.
My goal is to use this setup for downwind runs, so reliability, portability and light weight will be the main focus.
I am thinking about the following parts based on my experience with first gen :
321c camdenbox or smaller
VESC MKS 84100HP
MAYTECH remote, OR some other BT remote (vesc has BT and external antenna)
6374 or 6384 with 3 blade prop
New quick release pod
Previous setup and issues :
Big board with battery in deck, board too heavy at 7.5kg dry. The volume gives good safety if anything fails at sea, but weight is a problem most of the times.
With the big foil and this board, it is possible to start when cells are down to 3v, as it really does not need a lot of power to get up.
4.2 25lt Surfoil with 1050cm2, not enough power to get started unless battery is full
Small HA foil is great to carve and pump, but would require higher power to start with a small board. I do not know if a higher power setup would allow me to start even when battery is close to zero. My idea is to have a light setup, you ahve to be able to utilise the full energy of the pack.
My current setup was 7S4P 21700 with a 6384 motor, and the 100mm tall camdenboss box. That comes down to about 3kg for the box, plus another 0.75 for the motor. With some waves, upwind/downwind and PNG 1300, I get around 1h of run time, for about 400 wh of energy. With a well tuned setup and with enough wind/waves, I think 250wh would be enough to have a good time, and comparable to the number of starts you could get on a downwind board with a paddle and good training,
First step is the new pod, using the same principle as the previous version but based on this one Hybrid Foils Nano Pod DIY - #41 by foiling_moose?
Now printing begins…
