ESC Flycolor X Cross HV3 settings on BlHeli 32
Regardless it’s a good idea to add battery grease to the pins everytime inn case of a leak. My tests show pretty its a solid second barrier
I use MR60 under water for 3 motor phases, with grease, nothing bad to deplore!
I use PAHT-CF for the banana plug connectors, so no issue, but my question was more would it cause the ESC to explode if 2 or more phase wires shorted during operation?
Yes, it could. When a short occurs the motor is not a motor anymore to the esc so there will be a loss of control, motor will lock itself with a voltage spike as result.
Any more advantages PRO vs usual? Is that case in Pro good for cooling like they saying in promo?
Ordered FLYCOLOR X-CROSS HV3 120A and thinking about backup Flycolor X-CROSS HV3 PRO 80A for 6374 assist build.
'Foil Drive Assist, DIY - #1614 by lishine
I think what happened (though it hasn’t been validated yet) is that during that session, I practiced raising the motor out of the water and then returning it. However, this time, I remember leaving the motor on while doing so. That sudden change in load might have triggered some ESC protection or caused an ESC malfunction, which I’ll investigate in the next session.
Although I intentionally left the motor on, this could also happen unintentionally. In light of this, I’m considering developing a solution to cut the PPM signal to the ESC and restore it once the motor touches the water again. Perhaps something simple, like two metal plates on either side of the motor pod to measure resistance, combined with a transistor to block the PPM signal, could work.
Or maybe a more complex arrangement is required, like height measurement: 'Daniels (un)geared inflatable (slowly built) - #87 by sat_be
I’ve done a few X Cross 160A setups for friends and have never seen this happen. Can almost guarantee the motors have been running while the prop is going in and out of the water.
Silly question but assume the battery had sufficient charge not to trigger low voltage cut off….
I have external heat sinks frequently splashed with water - could your X Cross be overheating?
I probably set the motor at max power and continued at max power above the water which likely caused the issue.
This is likely a consequence of inexperience. Pointing the board upwards is probably sufficient. I am experimenting. There’s very little information available on foil-assist techniques for those who don’t know how to foil yet
Ye, battery was full. No BMS, just fuse.
I doubt it’s an overheating issue for several reasons:
  1. The previous session was completely fine.
  2. The slowdown only began after a few startups and ollies, with rest periods in between.
  3. The ESC always feels cold to the touch (unlike the battery). Active cooling is a very effective type of cooling.
Slow down is caused by low voltage limit or temperature (lots of users set it to 90 degrees). If you’re battery is weak, you’ll see by the bargraph flashing on your Remote when you take off.
Cut off is caused by current limit protection reached. Generally set to 60 amp for the heavier riders. It’s a good " battery saver"
The experience was definitely similar to when the battery runs out of power. It’s likely that the ESC detected a pulse voltage sag and switched into a low-power mode as a precaution.
However, there are additional settings whose functions I’m not familiar with.
Did you test this new ESC?
I have 2* 200 amp blheli 32 on my tow, it works like a charm. And possible to set everything like Flycolor, I use the phone app personally
Is there a phone app? How do you connect, a bluetooth module?
Blheli on play store only, nothing for iPhone. Use the Blheli chip and an adaptor usb-usb C on your android phone.
Static tested today XCross 160A.
Just put the foil with the board on sand in shallow water. (Don’t do it - it filled the motor and prop with sand).
Flipsky remote L/M/H setting
Measured battery current with a clump meter at max throttle. Interesting results:
H - 150A-170A
M - 75A
L - 25A
In my setup (transparent larger than usual ABS box) I cool esc with small fans and small heatsinks.
Measured heatsink temperature with a thermocouple and inside closed box temperature with some gadget.
Environment temperature 22c
Inside box temperature reached max 35c.
Always max throttle.
H - Fans or no fans - lasted 10-20s till protection kicked it - depending on the starting temperature. The heatsink temperature rised in about 10s till 50c+.
M - Lasted much longer, but eventually protection kicked in, depending on the starting temperature - it can be 1m, or 10s.
L - could run all day long without triggering protection.
Fans kept the heatsink temperature at max 50c+.
Test without fans on L+M:
L 60s, then M 10-20s and again. After 5-6 cycles heatsink temperature risen till 65c and then M could not do 20s.
Temperature protection works such that soon after limiting, the ESC frees throttle again.
Conclusions:
  1. Seems like current max throttle at H is too much current.
  2. Fans keep the temperature lower, but usually 55c which suggest that larger heatsinks and fans will do better.
  3. Given sufficient current no heatsink will cope with such large amount of heat generated, because of the way these mosfets are cooled.
  4. For continuous operation (no falls, no waves, no pumping) with intermittent starts these heatsinks inside without fans are not enough.
  5. My explanation why adding only one side large external heatsink helps overall - it makes the ESC PCB cooler thus less heat left for the other inside heatsink.
Next to try:
Foiling full session on M without fans still with these heatsinks.
This is really interesting. I have been using the 160a esc but did have problems. I have a couple spare unused and would use them again if I could be confident with them.
How are you setting L/M/H? Is this in the flipsky remote or in the blheli software? I have only used the Maytech remote so not familiar.
@nekitesurfing
Yes, Flipsky remote
150A battery current is a lot more than you normally need, 75 is more like the normal max current. I wonder if these figures are correct.
Most batteries here can’t do 150A and at 12s voltage it’s 6.6kW, what was the voltage?
Ye, I am not sure as well about these figures, the clump showed it steadily. It is pretty good clump that I have used for low amps. I zeroed it beforehand.
Yes, it is very high current and power. I didn’t measure the voltage, it was hard with the waves there, but maybe I will do another session.
3p p42a molicel should handle such a current I guess… The fuse is 200A
Hi Rttn,
What did you not like?
Looking at the fact that BLHeli won’t let us flash anymore, I wanted to switch to a am32 EDC.
Bad idea?
Thanks,
Albin
